Engine Overheat Warning at Low RPM'S
hotajax
Crisfield, MD
Was trolling 1100 rpm's for a half hour or so, and the warning horn came on. The tell-tale stream was strong and steady, so I knew the water pump was not in play. Also had plenty of oil in the reserve tank. I kicked up the rpms for just a few seconds, and, voila, the overheat warning horn quieted down almost immediately.
So, is it my poppet valve, or more likely to be thermostat-related?? And how often should these components be replaced?
plymouthgrady
PLYMOUTH, MA
My $$$'s on the poppet. My '97 SWS II did the EXACT same thing-but we did all the expensive trouble shooting first.
NIGHTIDES
POPPET..Just clean it no need to replace it..
GT
South Shore - Long Island NY
I might have just been lucky but I had similar problem, but Ihad new water pump, good stream, and recently changed (spring) t-stats. Everyone pointed me toward the poppet, saying a grain of sand or salt will make it stick. One suggestion was to flush the motor with fresh water for 30 minutes ( I normally give it a 10-15 flush), and it worked. No more alarm problems.
plymouthgrady
PLYMOUTH, MA
Good point. The poppet usually "goes" after the water pump is changed but the poppet isn't.
Boats Rock
Milford,De
I had the same issue. Removed the poppets. They had a jelly like build up under them that stopped the flow. washed them out and flushed the ports. Ran all season with no problem. I include this as a winterization task when I shut the boat down.
