Engine tilt gauge
Grady 228
North Shore
I have a 2009 250 Yamaha and my tilt engine gauge is just blinking and not moving when the engine is being moved up and down. I've checked the lever down at the engine and that's moving fine. If it needs replacing how hard is it.
I don't think the sender is stuck. I might be wrong but I think that a flashing indication means the display has NO signal. The sender could be bad, the sender connector could be corroded or disconnected, you could have a bad wire or there could be a problwm with the connector at the display
