Exterior mount storage for SUPs and boards.
Paul02468
Freedom 307
Can anyone recommend a storage solution to transport standup paddle boards and surfboards while under way that mounts on the exterior of the boat (Freedom 307). Thank you!
I can't imagine that mounting on the exterior of the boat is going be wise - wave pounding/etc will put tremendous pressure on the boats/mount and your hull. I can foresee bad things happening.
Put them on the hardtop
Thanks. I am looking for mounts for hardtop, gunwale etc. Any suggestions appreciated.
But again, over the gunwale is not good.
Over the bow rail would be high enough - but that's really bad because it severely restricts your vision.
The aft gunwale, keeping them high enough, would be fine. Maybe those rod holder racks is what you're looking for?
A couple pieces of dense foam (even pool noodle) and a ratchet strap would work on the hardtop. Or you can go crazy and get something premade - lot's of options - easy to find with searching. Look for what suits you best.
