- Jul 12, 2010
Hello;
Thank you for your support.
I decided this winter would be a good time to tackle the plastic thru hull fittings. The inspection revealed cracking on the port-side deck drain. I also became aware that the previous owner(I have had her 3 years) jammed a small fitting in to the original fitting instead of fixing it correctly.
I have been looking at Perko thru hull fittings, but they all come with hose barbs. My deck fittings have PVC elbows attached. One of the deck drain hoses has as split and needs to be replaced. I guess the best thing to do is to pull everything inspect and replace.
1. Do I buy the fitting with the barb and cut it?
2. Any "gotchas" before I tackle this issue?
I have already discovered removing the passenger foot rest will help. I will use 5200 slow cure to allow more work time. I'm going with bronze, even though the chrome looks better. I have removed the hatch rings for significant more arm room.
Any and all tips, no matter how small are welcome and appreciated.
I am still amazed at some of the Grady design issues. Was bronze not available in 1990? I am at least very happy with the condition of all the thru hull fitting areas. Lotsa foam and very dry.
Port deck drain
Star deck drain
Star fish box drain
Port fitting, notice the smaller fitting screwed into place
Star same as the port
I got the feeling this is going to suck, but knowing they are done = peace of mind.
saludos
Art
Port deck drain
Star deck drain
Star fish box drain
saludos
Art
