Fisherman 222 CC Performance
pursuit2
Hello I am trying to understand why the performance I am seeing is so different from the brochure on my GW. It's a 1999 222 CC Fisherman repowered with an F225. The spec sheet says 6100 RPM and 43.8 MPH top speed. I am nowhere near that. 1/2 Fuel and just me on board, and I'm topping out at 5400 RPM and 34 MPH. Bottom is clean and engine runs and sounds great. I'm assuming the prop is factory, but not positive since this is only my 2nd season owning the boat. I don't really need to go 40+ MPH, but just concerned that performance is so far off the spec sheet. Thanks!
Sounds like you've got the wrong propeller on there then, or something else is quite off. It's not exactly an apples to apples comparison but I've got a 2004 Grady White 228 Seafarer with a 2004 Yamaha F225 on it, of which the performance bulletin says she'll do a top speed of 44.6 mph @ 6,100 rpm. I don't get quite those good of numbers but with just myself and around a half a tank of fuel, I'll do around 41-42 mph at top speed while being close to 6k rpm for my max rpm. My boat is also going to be a little bit heavier than yours as it's a walkaround, has a full cabin/hardtop to it and per the performance bulletin it says the test weight of the boat is 5,361 lbs, compared to yours at 5,004 lbs. So... with the same motor and I'm guessing the same hull but being over 350 lbs lighter, I would think your boat should be at least doing the same speed as mine, if not faster. It definitely shouldn't have a max speed of only 34 mph and at only 5,400 rpm, it should be running at near the redline, which I'm guessing is that 6,000-6,100 rpm range. Here's the performance data sheet for my boat, I've got a 3 blade stainless steel prop on mine that came with the boat when I bought her back in October of 2021, but I'm not sure of the diameter/pitch off the top of my head. Good luck!
Reactions: Sharkbait1
what prop is on the boat? how are you trimming the engine at wot? do you have a lot of gear in the boat?
Reactions: igblack87
I'm really not sure what prop is on there, I just assumed the factory prop. I'm going to pull it off and see at the end of the season. I have almost no gear on the boat, it does have a canvass T-top though. I didn't adjust the tabs when I tested the WOT, but the bow was quite far down, so I assumed no tabs were needed. I don't have much experience running a small boat like this.
Thanks and my guess is that since I am that far off, maybe the prop was damaged and replaced with one that isn't really suitable. I'll investigate that once I haul and get the prop off.
you dont need to take it off to see. it should be stamped on the barrel/tube
Reactions: pursuit2
I have a 2001 222 Fisherman, with a 2014 Yamaha 250, and easily hit 43kts at 6200rpm. That's with the motor trimmed up, on flat water, with about 700lbs of dude onboard...
Need to know prop specs, pitch and diameter. How was speed measured?
Is the bottom painted?
You also need to look at the current prop for signs of damage, distortion of blades and/or spun hub.
Bottom is painted and clean. I measured the speed via GPS in the Bay and used a two way average to account for wind and tide. Current plan is to haul late Oct or early Nov and get a look at the prop. Thanks for the replies. Not much to do until I get the boat hauled.
So I agree with the guy who replied 1st.
I just re-powered my Grady White 257 in advance with twin Yamaha F1 50s. They were only getting about 5300 RPM. The dealer instantly knew this wasn’t correct after he switched the props and I am now getting the exact results. I am supposed to be getting. have the dealer Change the props it should be at no cost to you
Hope this helps. Good luck.
Reactions: Mustang65fbk
