- May 27, 2020
- Age
- 69
- Fisherman 222
Thank you for the quick response. Headed to the shop tomorrow for 20 hour service. Hope it’s a simple fix!That boat is configured with a F300 motor. The F300 motor has a water pressure sensor. You probably need to have a mechanic look at it. The boat should be under waranty I think.
It wouldn't be a wire that gets a kink. It might be a hose but I don't remember if the sensor screws right into the power head or connects with a hose. Regardless, if the alarm is still there, I wouldn't accept their explanation. Push the issue if you have to.Didn’t get much of an answer ... Tech said, “Sometimes the sensor wire gets a kink and can’t send pressure reading.” Really? That’s OK on flagship product? Wow.
www.boats.net
