- May 16, 2011
- Inglis, FL
- Express 330
After having the 2007 generator run all night offshore for air conditioning, the next day would not start. Troubleshot relays fuel pump etc. and the final fix was an adjustment of the valves. As it turns out the intake valve was not closing completely, thereby reducing compression and allowing the high compression diesel engine to not start. Adjusted both valves to specifications running great starting easy. Not sure why the valve lash went away maybe after running all night the carbon on the valve seat had been reduced.
