- May 13, 2024
- Age
- 72
- Freedom 307
My 307 has a center bilge with no bilge pump. The problem I have is when it is at the dock any water that gets into the rear bilge drains to the center bilge where there are 2 valves for the toilet. These valves are often under water and the only way to remove the water is with a wet dry vacuum. Has anyone else experienced this and if so is there a solution.
