- Mar 7, 2018
- Age
- 67
- Miss Gulf Coast
- Freedom 205
What happens, the channel overflows and seeps between the top lip and cover. I'm not talking a deluge but enough to wet the contents where they need to dry to keep from molding. The lid fits tight so it would have to be a very thin gasket. Just wondering has anyone resolved this issue.
If it's overflowing, it sounds like the boat is not level (or slightly bow high)? If it's level/slightly high, you would think that the water should drain out before it overflows?What happens, the channel overflows and seeps between the top lip and cover. I'm not talking a deluge but enough to wet the contents where they need to dry to keep from molding. The lid fits tight so it would have to be a very thin gasket. Just wondering has anyone resolved this issue.
You would think so but I can see how this happens with this design. Yes if the boat was level and listing slightly inboard maybe, but that's not always the case.If it's overflowing, it sounds like the boat is not level (or slightly bow high)? If it's level/slightly high, you would think that the water should drain out before it overflows?
Hmmm. That's strange. It sounds counterituitive to the intended design of the water gutter. Maybe the gutter was formed wrong?You would think so but I can see how this happens with this design. Yes if the boat was level and listing slightly inboard maybe, but that's not always the case.
Thanks, I thought of that also. From what I can tell I would need something that compresses next to nothing and still creates a seal. I believe on the newer Freedoms they redesigned these to be watertight.This will work. It's flat, self adhesive, and should do what you want.
I've used it on my boat for the hatch going into the cuddy.
Look on Ebay and search in Grady-White boat parts. Taylor Marine, Grady dealer in Delaware has it for sale.
I take it your "hatch" is on a hinge? If so, there may be more space between it and the "boat" than you're thinking. Meaning, a thin gasket, like I mentioned above, would probably be just fine. Easy enough and cheap enough to experiment with.Thanks, I thought of that also. From what I can tell I would need something that compresses next to nothing and still creates a seal. I believe on the newer Freedoms they redesigned these to be watertight.
No not really. I do keep mine under cover so I usually just let it dry out first which involves removing the contents. I have just learned to live with it along with the anchor locker draining into the forward bilge.Capt Tom - Did you end up doing anything to resolve this issue? I am having the same problem.
