So, went down to the boat today to prep for the 4th. Turned on fresh water switch and pump comes on, no water from any outlet.
Filled tank until water runs out of top of tank and tried again. No water to system. Accessed the pump and checked filter....clear and clean. Turned on pump, filter removed, but seems no water to the pump while outlet is open and no water apparent in inlet hose(from tank).
Clog in supply system?? Thinking of using my air compressor to blow back to the tank from the pump supply side. Any thoughts?? Hate to think of running new hose and accessing the bottom of the water tank(aft of the batteries and shelf, etc.) I am obviously hoping that since the pump will switch on that it is working.
posting.php?mode=post&f=3&sid=9ab71b6722317b40ba5777d1e213dbca#
