No I'm not sure its still has strength just looks like it's heat shattered?Are you sure it is glass? If you carefully press it with your thumb, dose if flex?
Thank You! Will look into this.Sounds like "crazed" plastic. It's only held in by adhesive caulking you see running around the edge - it's first bedded in the caulk. BoatLife Life Caulk would be an excellent choice, although there's certainly others.
Thank You!https://pompanettellc.com/product-category/hatches/ - This is the manufacturer of Bomar hatches which is the maker of the hatch on my boat
Thanks will check it out. appreciate the tip!I dealt with this exact situation. My dad lost his balance on the bow and his butt cracked mine. Tried for a couple weeks finding a local source. I ended up ordering a new one from this site. It was quick and easy to deal with.
Lewmar Hatches |MAURIPRO Sailing
Ensure secure and watertight access with Lewmar hatches, designed for durability and convenience.www.mauriprosailing.com
