Fuel consumption
rcornejo
San Antonio, Texas
Does anyone know what the mpg is on a 1999 208 adventure is with a 1999 175 2 stroke saltwater series outboard. I know it depends on the user and rpm's but as an average doing 3500-4500 rpm's. Any information would be helpful.
Roland Cornejo
You would see a burn of about 7 to 12 GPH. The difference between the sweet spot which is about 3800 to 4000 rpm and 4500 is fairly significant. Of course a lot depends on wind, current, drag and propping. If you are making 32 mph at 4500, that works out to 2.5 to 4 mpg ( In theory of course) On my 208 with a 150 Salt Water series, I average a little over 2 nautical miles per gallon in a season. My boating includes a lot of drifting and start/stops.
DB
Ocean City, Maryland
GPH
A 175 2 stroke is going to burn around 25 gph at WOT at 4500 somewhere around 19 at 3000 - 4000rpm around 12 - 15 hope this helps
rcornejo
San Antonio, Texas
Thanks for the information. I did not realize that it would use that much fuel. Do anyone know if Grady has that data as they do with the new boats?
Re: GPH
Sounds high to me. The 208 is a 3,000 pound hull. But then again, I have been wrong before:)
rcornejo
San Antonio, Texas
Thanks,
I thought that seemed a little high, I would suspect that you would burn 10 to 12 gallons per hour at 3800 rpm's. Does anyone have better numbers.
Roland
gwwannabe
Piankatank River, Gloucester, VA
DB, my model year 2000 200 HP Johnson only burns 23 GPH at WOT (5800) on my 89 204C Overnighter. I would think his motor should do a fair amount better, like in the 17 - 18 GPH range.
RCORNEJO, I have a Northstar fuel monitor so I have some pretty good numbers for my boat. I think your boat and motor will be a bit more efficient.
At 3500 rpm I'm burning between 8.5 and 10 gph, according to my Northstar fuel flow meter. The variation depends on weight, wind, waves, tide, etc. I average about 2.7 mpg at this rpm range on down to about 2 at wot, about 5800 rpm. Speed is around 26 MPH according to the GPS.
At 4000 RPM I'm seeing about 32 MPH and 2.5 MPG. When I push it to WOT, my Northstar fuel flow meter is registering about 23 GPH and my GPS is registering right around 40 MPH - sometimes a bit below and sometimes a bit over.
Hope this helps.
Gary 93 Gulfstream 89 Overnighter - for sale
rcornejo
San Antonio, Texas
Hi Gwwannabe,
Thanks for the numbers. It really helps to have a machine to help monitor the numbers. That helps me a lot. It is amazing how much fuel you can use/save between 3500 and 5000 RPM's. :!:
Thanks again for your help.
Roland
