Fuel cutoff.
Cstrickland
Where is the fuel shutoff located on a 2010 29 Chesapeake? Any help appreciated can not find in owners manual.
thank you
I'm guessing aft. Open the drop down panel under the fold down aft seat (swing the seat out of the way up onto the fishbox).
To the left looking in, you will see two rather larger cocks with a pointed edge. The edge points forward or aft depending on tank selected.
Does the OP want to find a fuel shutoff or a tank selector?
There may not be a fuel shutoff valve.
It is a 3 way I believe - worked short term on my boat. If I remember, pointing forward is usually main tank, pointing aux tank (180 deg between both). Try stopping 1/2 way 90deg for off.
