- Sep 26, 2009
- Massachusetts
- Express 330
Have a pair of Yamaha 225's on my 330 with the standard gauges. Did a long run the other day, and have a question about what I'm seeing. Prior to trip, I filled up both tanks. Both tanks started to bubble fuel up through the vents at the fill. I slowed down the flow and pumped a bit more into each. The main tank gauge read 7/8 bars, and the aux gauge read 8/8 bars. I reset the fuel used. My set up is to have one motor run off of each tank. The trip burned 175 gallons per the gauge. This is about what I expected, given we went ~75 miles each way, plus 7 hours trolling. Upon return to harbor, the gauges read very low. Aux was approx 2/8 bars, and the main was 3/8 bars. I would expect there is still approx 120/200 or 60% in main, and 70/150 or 46% in aux tank.
Short of topping off the tanks again, would you be more inclined to believe the fuel used, or the tank level?
Also, do others have to slow down when topping off the tank, due to the vent?
