- Oct 18, 2013
- Age
- 66
- Farmingdale NJ
- Overnighter
I have been figuring out how I am going to layout my new instrument panel, shopping for gauges and switch panels.
The panel has four gauges that are from Suzuki and matched to my outboard so even though they wouldn't be my first choice for style. They have a black background and I'd rather have white but its easier to work with them. The other two gauges are nowhere close in style but I found that VDO marine has a voltmeter and fuel level gauge that match almost perfectly.
As for the switch panel I will be using the Bluesea weatherdeck fuse panel. I'd considered but decided against the circuit breaker panel for two reasons. First the fuse panel is a little slimmer fitting the dash better and more importantly I can lower the fuse amps down by simply changing the fuse. Both come with 15amp protection and buying the lower amp breakers to swap out the 15 amp units bump the bottom line up considerably if I went with the breaker panel.
One other thing I like about these panels are that the labels are back lit, red/green or if is nothing is lit well the fuse has blown. Simple enough.
Ok heres where I have a question....
Going though the provided labels I did not find one for "fuel" as my Grady came with. That switch simply throws a signal to the fuel gauge permitting it to show the level.
But why? Is this switch really necessary? My Bayliner's fuel gauge was powered by the ignition circuit as are the four gauges provided by Suzuki, (Tach, Hobbs, oil level and trim). Does anyone really see a need to have the Fuel gauge separately powered?
Mike.
