I'm thinking about replacing the fuel lines on my 2001 265 and seeking some advice. No issues with fueling but I'm thinking about 10 years old should be time to replace? The fittings back by the fuel bulbs look a little aged so that is what got me thinking. Instead of trimming off an inch or so and reclamping the ends, how big a job is the full hose swap out? I have access to the tank connections via deck plates - do I have to raise the entire floor panel or can I just disconnect and tie off a line, pull out the old and then pull through the new? I was also thinking about changing out the fuel filter mounts becasue the originals look a little aged. Have seen a post somewhere about an upgraded stainless version - anybody source those, or is that overkill??
