Fuel tank selector valve replacement
southernstyle995
I need to replace the 3 position fuel tank selector valves on my 265 does anyone know where to get them? The only ones I can find have the inlets and outlet pointing out and not down
Bob Meola
southernstyle995
Just got the Moeller 3 way valves and they are the correct ones. The do click
southernstyle995
I forgot to take a picture which tank is the main? The one in the front or rear. Mine are marked with red and green tape
southernstyle995
Quick note tho on the package it says this is not the "click" one but it does click, now it's not as noticeable as the old one. I looked the click part number up on the same website that I got this one and nothing came up so not sure on that. But I can live with the one I got
southernstyle995
Does the 265 have anti siphon valves for the fuel system. If so ate they on top of tanks?
I don't know. Normally they are the hose barb on the elbow on top of the tank. You can't tell by looking at them if they have antisiphon. The PO of my 265 changed the tanks so I have not had any reason to take anything apart.
southernstyle995
10-4
Ajon
I have a set i took off when I added the bladder line.
