I have the 1934 version. The current inexpensive in-hull transducer does not meet my needs, as it will not read bottom reliably in over 400' nor does it read temperature. We fish the NJ canyons and I need to be able to read bottom in at least 1500' of water and being a tuna fisherman I need to find those temperature breaks.
I have been trying to decide what would be best for my needs and assumed an 1000 watt in-hull M260 style wired in with a transom mounted smart sensor would work best. In addtion I have been convinced the Furuno RD30 would suit my needs as an extra temperature gauge (or whatever else I want to display at the time).
Now Airmar (transducer manufacturer for almost every brand) is coming out with a 1000 watt transom mounted transducer, that has the same 'guts' as the B260 thru-hull and the M260 in-hull. I would only have to install one transducer, only wire one unit and pay for one transducer. Would it make sense for my needs to go this route? Do you think a large transom mount ducer is going to be a problem with outboards?
What are you guys using? Do I need a second transducer with smart sensor technology for the RD30? Do I need a 'super' sensitive temperature sensor for finding those temperature breaks or is any transducer with a temperature sensor adequate?
Please share your ideas before I pull all my hair out...
