Fuse panel corrosion
Stowefish
This spring, got the boat out of storage up north and there was a fair amount of pitting/corrosion on the fuse panel. Other than more desiccants/moisture reduction, is there a spray that can be used in the center console on the wiring and fuse panels to reduce corrosion? Any input appreciated.
joker
CRC 656 also very good to fight corrosion
Stowefish
Thanks for the reply! All of these can be sprayed directly on wiring/plastic/fuse panel?
The T-( can, just use a light coating. No need to make a mess.
Doc Stressor
Homosassa, FL
There are a lot of products that do a good job of preventing corrosion. Corrosion X is the only one I've used that will actually remove corrosion from surfaces.
