Fishin' Rod said:
I have heard of the transducer being mounted inside the hull. Do you know anything about that?
You can mount your transducer inside the bilge area, if the transducer has a relatively flat face. This method is called, "shoot thru". If it's not flat, you'll need to purchase a shoot thru, or "puck" type. You will lose water temp and speed, unless they have seperate pick ups, which are mounted outside, where your original transducer is, (not sure if that's available for the 240). You will also lose some transmitting power, but imo, the 240 would be fine. I had one and had to adjust the gain down to 40 - 50% because of all the "noise" on the screen. A Garmin service tech actually recomended that.
If you decide to do the shoot thru set up, you should be able to find a decent flat area infront of your bilge pump/float switch. Clean the area with acitone, sand it a little and clean again with acitone. They recomend that you use an epoxy to mount the ducer, but you really don't need it. Just use a good marine sealent like Life Seal or 3M's 4200. This way, if you ever need to remove or replace it, it won't be too difficult. I've done a few like this and they worked out great.
Since your in a slip, this might be a good option. Leave your existing transducer in place, purchase and mount the shoot thru ducer. Just disconnect your transom ducer and plug in the shoot thru. You can deal with the transom mount later.
