Garmin reactor 40 auto pilot location
thepenman
Miami
I have looked every where in my boat. Under the helm. Aft cabin port and starboard access panels. Found the smart pump in the starboard side aft cabin. Not behind the electric panel. Not in the control switch panel. Not in the helm starboard access panel. I don’t have a port access panel. Anyone have new ideas????I need my auto pilot back. Needs to stop saying “searching for autopilot controller”
ElyseM
highlands, nj
could be in the space behind the instrument panel; under the electronics pod well; or under the electronics pod "deck" (i stuck my gsd22 up under there). also, i put my heading sensor in the locker in the cabin (you have to look up to see it). you should have something in the helm portside, could be there. i had a 2009. good luck, ron
You say you "found the Smartpump". If the pump has no power feed you will get that error.
Are you looking for the Attitude Heading Reference System (AHRS) ?
Ideally it would be centerline and low. Follow the wire...
drbatts
CT
look on the inside or the underside of the tub for the electronics box.
everwhom
Cape Cod and Nantucket
Mine is under the livewell accessible by removing the tackle drawers... Each installer chooses their own location and that's where mine wound up after being moved because of electrical interference (compass would deviate like crazy when I operated the trim tabs). Tracing the cable from the pump may give you hint... Or maybe you can ask the original installer?
ElyseM
highlands, nj
that's a bear. it does come out. look in all the easier places first. good luck, ron
drbatts
CT
Try removing the switch panel on the dash and looking down there. You may have to just try following the wires from either the pump or the NMEA backbone hopefully whoever installed it labeled the wires.
thepenman
Miami
I’m looking for this. Garmin reactor 40 Auto Pilot.
thepenman
Miami
The wires from the pump go into a “hole”. Not traceable.
thepenman
Miami
have you checked the fuse to the pump? You will get that error if the Smartpump is not powered
Pump has power. Status blinks rotating color from red a few blinks then green a couple of times
thepenman
Miami
If the fuse isn’t on the main panel. I wouldn’t know where it is.
there should be an inline fuse at the power source end of the power cable.
Normally it would be connected after the House power switch/breaker.
Sometimes people put a dash switch to power the Autopilot.
I would assume since you have lights that there is power there...but...
wspitler
Inglis, FL
Make sure to look way down at the bottom, behind the cabin electrical panel. Mine is down there and very easy to miss. You can also see the bottom of the pop up electronic box from behind that panel. Good Luck!
thepenman
Miami
Pump has power. Status Light blinks red a few times. Then green.
thepenman
Miami
I opened the electrical panel. Three screws. Swings open. Are u suggesting to remove the whole electrical box? I’m guessing I’ll need to shut off all power to the boat.
thepenman
Miami
auto pilot has its own breaker on the panel.
can't help you find the unit but I'm interested in the problem you are trying to resolve
Your error is displayed on a GHC20 or Garmin MFD or both?
thepenman
Miami
On ghc20. “Searching for auto pilot controller”. Talked to Garmin. They can’t help me w/o knowing what the reactor 40 is “saying”
