Gents -
I was having some work done on a 98 (replacing the fuel senders) and the mechanic indicated that there was a fair amount of pitting around the sender hole. He does not think that the new gasket will seal and indicated that in this case the entire tank (150gal) aluminum tank should be replaced. Because we will have the deck covers up it would also make sense to replace the aux tank (also 150) and hoses fuel lines etc etc etc. the tank is pitted - and I do trust him - but wanted a second opinion if anyone can help.
:hmm
When is it time to replace if it is not leaking?
:hmm
