I have a new to me 1987 206 Overnighter that was fresh water only and is in very good condition. I took it out for a sea trial and saw the water pump was spitting water inconsistently and then got a overheat alarm. I still bought it and immediately took it in for a new pump and engine look over. They found a bad impeller and replaced that along with a head gasket and stator. I ran it hard this weekend and the alarm went off again for a minute, then stopped, good water running out of the engine. Alarm did not come on at all the rest of the outing. Is there any way I can put a temp gauge on the boat and run it off the alarm sensor wire? I am wondering if anyone has experience with these ghosts?
Secondly, my RPM gauge runs to about 1000 RPM and then drops dead, if I tap it, it blinks up for a sec and drops off. Lastly my trim gauge does not work at all? Do I just start testing the wiring behind the gauge panel, or is there something specific? thoughts?
I might as well though in the hydrolic steering being sluggish. I noticed after I got back to the dock that it was very low on oil. So I topped it with ATF like the manual said and a lot of air burped out. Do I also need to bleed the lines?
Overall the boat ran and performed well all weekend. I had the hull looked over by a fiberglass guy and it was pronounced sound.
Thanks in advance for any advice or info. I wonder if the right thing to do is taking it to the Grady Dealer 2.5 hours away and let them go over it. I would like to do as much myself though, gets me more familiar with the boat.
Alan
Alan
