Generator won't stay running
dgreen1069
I have a Kohler 5e generator on my 2000 Grady White Marlin 300. The boat is new to me and has not seen a lot of use.....the generator has a whopping 4 hours. At first the generator wouldn't start. I suspected it may have been because my fuel level was low so I topped off my tanks. The generator started right up and ran for approximately 5 minutes without a load. It was putting out 120 volts and appeared to be working. All of a sudden, the generator quit and will no longer run.
The generator will start right up, but cuts off as soon as I let go of the starter switch. The problem seems electrical, but I know little to nothing about generators. If I hold the starter switch on, the generator will keep running. Any help with my problem would be GREATLY appreciated.
Dave
Gman25
Bayshore, NY
If it starts and then shortly cuts out after starting I would check the fuel pump..Sounds like what mine was doing before the pump went bad.
'05 300 Marlin F250's
