Getting close 1983 seaferor
Tdurr22
Well bought my 83 seaferor for 200$ in October, since then I've rebuilt and reinforced transom ,added a bracket with a swim platform,fixed the soft floors,new fuel cell and moved it forward,added a fish box in the extra space and now in the process of a total rewire.got blue gunnel lights and under water lights installed along with radio,VHS,gps and adding a few more speakers soon.more pics to come. 225hp 2 stroke Yamaha am I under powered boat is 26' tip to tip once pulpit is installed it will be 27'6
Good luck with the restoration. I assume the model is a Saefarer:)
Other than the effect of the added weight of a pulpit, the extra length doesn't really affect performance very much since it is the length on the water and not the length overall that is a factor in performance. The added length of the bracket will have a lot more to do with performance and handling. The 2 stroke is lighter than a 4 stroke 6 cyl would be. That could be a consideration down the road if you repower. Note that max HP for a 1983 226 seafarer is 260 HP.
Look like you're making good progress!
Keep in mind it's still just a 22' boat - the other stuff that adds to the length doesn't matter. No, it's not underpowered at all. In fact, it should do REALLY well. The bracket will help performance, too. I have a 250HP on my 24' Offshore and it runs amazingly well.
Question... will mounting the speakers the way you are doing it allow water to enter the holes and then stay strapped, at least partially, between the fiberglass and the speaker... possibly even filling up the lower section of the speaker?
efx
Los Angeles
Wow, awesome project. It’s great keeping these classic hulls still up and running. 225 hp is plenty for this hull. I had a 92’ 228 with a 225 and it was perfect.
Reactions: Tdurr22
Agree, the boat looks very nice.
Tdurr22
I thought about that and to solve that problem I sealed the holes with clear laquer. Will probably need to be done once a year as far as the speaker trapping water I don't have them right against the well I put a cpl washers in-between the speakers and the gunnel we will see how it works hopefully everything will work and function as I had planned. Time will tell. I just didn't want covers because they fade and crack and eventually break.
Good idea with the washers - creating a "drain hole", so to speak.
