GPS Antenna ?
Legend
Southern New England
HI. Purchased a new multi-function Garmin GPS unit and it says it has an internal antenna. Has the option for an external antenna. Anyone with a fairly new GPS using just the internal antenna and is so any issues with satellite reception? The unit is to be installed in a Sailfish, under the hardtop and surface mounted in the cockpit. Thanks for any feedback.
I’ve installed a few, all with internal antenna and never had a problem picking up satellites. A couple were hardtops.
You should be fine and if not add the external antenna later.
Same as Coastboater here. Just connect your Garmin to a NMEA 2000 system and all your other instruments will be able to make use of it. Like your VHS, autopilot, or any NMEA 2000 capable gizmo.
mine is mounted just above my steering wheel (so lower than yours), i have no external antenna and it does fine
