ROBERTH
- Jun 10, 2006
- Greenville, NC
- Sailfish
In regards to the 10 micron vs 2 microns.
10 micron is rated at 90 gph flow.
2 micron is rated at 60 gph flow.
I think the Yamaha engines from 200 to 250 hp use about 19-24gph max at wide open throttle.
Being that we don't run wide open, the actual flow is much less.
So, the rule most folks are running with is to change your 2 microns every 50-75 hours if you are concerned to be safe as the 60 gph has less margin in comparison to a 90gph at a 10 micron rating.
However, some folks are monitoring their fuel vacuum and finding that they are getting well over 100 hours with no sign of restriction of maximum vacuum per engine specs.
I changed mine every 50 hours for first season, and now run to 75 hours and no issues.
I also pulled the fuel senders and shine a flashlight down and view the debris in the bottom of the tank and compare that with what is in the clear fuel filter bowl and use that as a determining factor on how soon to make the change. If I find a lot of grit in the fuel bowl site glass, I change it at that point. Mostly, the bowls are very clean.
