Bottom of page 6-5 in the manual states the 40 amp breaker supplies power to the accessory switch panel.
http://www.gradywhite.com/customer/manu ... &model=232
Unfortunately the manual does not clearly show how the fuse blocks, (dash and hard top) are supplied, but page 6-18, (hard top wiring) does show the fuse blocks are jumped together.
Looking at the wiring diagram on page 6-16, it shows 2 sets of feed wires exiting the rigging tube, (10 gauge red and black). 1 set for the fuse block and 1 set for the switch panel. Ok, that makes sense, and it might explain why your electronics work, but the switch panel doesn't. However, back at the battery, the diagram shows only one 10 gauge red wire coming from the 40 breaker and one 10 gauge black, (battery ground). Kind of confusing.
So... where is the supply for the fuse blocks? Are there 2 supply wires fed from the 40 amp breaker, (one for the switch panel and one for the fuse block)? And, are there 2 seperate ground cables at the battery? I'm only saying that because of the diagram. Or, if it is a single feed from the breaker, is there simply a jumper wire or buss bar connection, (like seasick suggested) from the fuse block to the switch panel, and one ground at the battery.
If it's a 2 wire set-up, I would first look to see if there's a bad ground cable at the battery. Or...
Did you recently replace the battery, or do some wiring? You might have actually missed re-attaching a ground cable. 2nd, (again, if it's a 2 wire feed) check the red cable connections at the breaker.
If it is a single wire feed, check the red supply wire on the switch panel with a meter. Check the connections, (red and ground) to make sure they're tight and clean as well.
Also, power runs to the first breaker, "cockpit lights". on the switch panel, (see page 6-eight). If for some reason that 1st jumper is lose or disconnected, you'll lose power to everything on the panel. Might want to check that out.
