American Offshore Fishing
Gulfstream e-tec 300 G2 performance
artodea
Boston Northshore
At the request of another member, I have the following performance numbers on my e-tec G2 300 hanging on the back of my 1996 Gulfstream 23. I am starting my fourth season with the engine and I have absolutely no regrets with the re-power.
Three seasons, (only 228 hours - I need to stop letting life - and work - get in the way of boating)
Fuel consumed: 647.9 gallons
Oil burned: 9 gallons ($300), or 71.98:1
Maintenance cost: $42 (I change the fuel filter annually). I did change the gear oil when I removed the lower unit to weld in a replacement skeg after a rock took it off, but I wouldn't have done that otherwise
I get 2.4 mpg at 4500 rpm running 33 mph, 2.6-2.7 mpg between 4000-4200. WOT gets me to 43 mph at 5900, light load. I have the 16 pitch RX-4 prop with the engine all the way up on the bracket.
The things I like:
Every time I start, it kicks over after about a half-turn of the flywheel. Literally, touch the key and she's running. Every single time.
The torque is amazing and well matched with the 232 hull.
The engine fully tilts out of the water. The skeg does not need bottom paint.
No break in - and absolutely no worries about making oil.
Power steering and auto-trim - both just work great
The lower unit oil has a translucent reservoir behind the engine panel to check level and oil condition
Winterization at the touch of a button - the engine fogs itself.
It's quiet (though not silent at idle like some four-strokes) and there is no smoke. I had an issue with the power steering cutting out in the first season but I did not lose the ability to steer. Just the assist. The dealer had me back up and running in a couple days.
family affair
Ohio
Grady White Model
Impressive numbers! Great write-up too.
2016 engine?
artodea
Boston Northshore
Bought and installed in 2016 - the engine is one of the early ones with a Nov 2014 build date with all updates factory-installed prior to purchase.
LongIslandGulfstream
Grady White Model
Thank you very much for the summary. Now only if they weren’t so darn expensive!
family affair
Ohio
Grady White Model
Good to know an early production, updated engine can be reliable.
