GW 1999 seafarer 228 fuel tank replacement
Timcan
So my winter project was to replace all the fuel hoses, pull out my main tank, inspect it and done. Ha nothing is never that easy my main 92gal tank turned out to be badly pitted on the bottom so it needs replacing. The previous owner replaced the auxiliary tank but whoever did the work cut some corners. They didn’t replace any of the hoses and spliced the fill hose. I’m in the process of getting quotes for the main tank so if you have anyone that you recommend I’ll be very happy to take their contact info. The hoses were not difficult to remove at all. The tank was a little more challenging because I had to grind/sand the hatch lip so the tank can be removed. I will probably end up glassing the corners on the aft lip a little. So once I get a tank I plan on putting an epoxy coat on it and gluing (5200) some strips of expanded pvc on the bottom. I’ll post my progress as things move along. The good news is I’m doing this on my terms so I can take my time. Our fishing season doesn’t start until April/May.
Well you got the tank out successfully. Looks like you will be able to drop a new one in and connect up with little probs. Sorry to see the hose connections on the Aux tank. Can't believe someone would do it that way on any line especially a fuel line. Might want to see if you can get the new tank up a bit to keep it from sitting in any water. Nice job so far.
A quick update new main tank is in. I sanded the tank and quickly coated it with zinc chromate primer. Then I gave it 2 coats of Coal Tar Epoxy. I 5200 2 plastic strips on the bottom of the tank to lift it from the floor. I removed my newer auxiliary tank to coat it with Coal Tar and do the same as the main. Fill and vent hoses are in it was challenging but it’s doable without cutting an access hatchF31E3542-5603-42BD-A9A3-BBF5DCF4D731.jpeg85A1C758-1954-4FBA-BDF1-AC2F313E3AE9.jpeg87985C6B-B352-4183-AA30-9F4E4A05A388.jpeg
Here are a couple other photos.
