GW logo and registration numbers question
SeaVee
All, the port side GW logo on my 2001 has lost it's "G". Customer service says they don't have this style, anyone know if someone else may have one? Also, I'd like to have my registration numbers with the same color combo and font of the logo , any ideas on where I could get that done?
TIA,
SeaVee
Jonah
Bahamas
Hi SeaVee,
I asked something similar on this forum once, and found a number of other threads about the same. I'm on-the-go right now, or would pull them up for you. Just have a search, and you'll probably find some older threads about this.
Parthery
Atlanta, GA
Look on eBay....there are still some old logos to be found from time to time. Alternative is to order the new logos and replace both sides.
As far as registration numbers are concerned, if you go to http://www.boatus.com/graphics and order the navy numbers with gold outline, they match almost perfectly.
I'd ask the factory for the manufacturer name and contact.
SeaVee
Thanks guys, the factory said they only had the current logos, so may have to go that route
drbatts
CT
Any graphics shop should be able to make the correct and/or matching decals for you. Both for the Grady logo and reg. numbers. If your boat is named the shop that made the decal for the name maybe a good starting point. I personally removed the side logos as I prefer the cleaner look.
the stock ones are not cheap....
Check with your state regs on the numbering. It may specify size, font etc.
ioffe
Jersey City, NJ
I think I might have full OEM logo for 2007 Gulfstream (please check if its the same).
SeaVee
This is the style I am looking for:
