hard re-starting engines
fearnofish
beach haven west, new jersey
i have a sailfish with twin 200 2001 mercurys saltwaters carb engines. engines start fine the first time but after they run they don't want to start. there are two ways i get them to fire. 1st is a fast start throttles engaged then i pump them with long turn of key. or i just do a long turn of the key almost like they are flooded and need to burn off fuel. i know it contradicts it self but either way will get them going. any ideas?
Grog
If the bulb is staying hard it's probably the carbs needing a rebuild.
jmphoto
ct
hard start
I was having the same problem with my 175 mercs but I have noticed if you lay off the choke altogether they start back up, its one of those less is more things a little throttle and no choke. good luck
fearnofish
called my mechanic today he says the older engines carbs have aluminum floats. the new engines have plastic. what it is, that the ethonal i the gas evaporates at a faster rate because the metal retains the heat so they stay hotter causing the engines to be primed again. this only occurs if the engines sit for longer then 20 mins if it's 10 mins they start right up. it's both engines not just one.
