Yep, I removed the front windows, took them to an automotive glass shop and had them re-bed (silicone) the glass to the aluminum frame. I reinstalled them into the very sloppily cut fiberglass openings and was good for about two years. This past summer they started leaking again but I purchased new ones on Ebay for $70 and will install them this winter. I may try to build up the edge of the cut out but I don't think it would be easy. The side sliders are also leaking and I will probably remove them as well and see if I can repair the seals. There is a drain hole at the rear corner of the frame to allow water to flow out. Mine were filled with crud. 95 Islander
