Idle on F225
Lainie J
Does anyone know how to raise the idle on a F225? One motor is at 500RPMs and should be at 700RPMs.
bdubz06
Seattle, WA
Is this something that needs to be done by a Yamaha mechanic? Mine idles about 500 rpms as well and lately coming off a plane down to neutral the engine will shutter a little bit and then idle like normal. Sometimes it shutters too when kicking it in gear. It should be at about 700 rpm, correct?
Thanks.
wahoo33417
West Palm Beach, FL
700 rpm at idle strikes me as bit high. A Yammi dealer once told me that about half of the EPA emissions test occurs at idle speed. That, he said, is at least partly why the idle is set low at the factory.
Anyone else hear that story? If true, might some techs be reluctant to raise the idle?
Rob
JUST-IN-TIME
ON THE WATER
you will need a good tach or YDS
do not raise your throttle to more than spec, unless you want to replace the lower unit clutch dog a lot
