Kind of a silly question about fenders, and lines… I need some for my new 216 fisherman…what size, how many, what color ?
sailUSVI
TX/Maine
Fisherman 216
I know it’s probably a personal choice but thought I’d ask anyway.
Going to pick up our brand new boat today and I’m guessing it does not come with fenders and lines.
Our old Whaler had red fenders to match the red bimini, my wife’s choice :cool:
Are you going to be slipping the boat, or trailering?
Reason i ask is that I find it helpful to have different color lines - this makes it easier for crew to get the correct line. When backing into my slip, I need the spring line to the aft cleat secured first. If this line is a different color, say green, it is much clearer to say grab the green line and... instead of get the spring line first. With a trailer, the lines are on the boat, so it is less important.
For a 21' boat, 1/2" lines are more than sufficient. I don't have a preference on fenders, both of mine are white. But last boat had black.
Reactions: sailUSVI
Your dealer usually provides the basic coast guard package along with fenders and lines. Give them a call.
Reactions: sailUSVI
Having different colored lines makes it much easier to instruct the crew or anyone helping from the dock. If your boat is to be kept in a slip consider getting a second set of lines to use for docking at other marinas etc. They also can be used to double lines up in a storm. Depending on the size of your cleats 3/8 inch line maybe a better choice.
Reactions: sailUSVI
Don't know about colors. I have a blue hull and went with blue fenders and blue lines.
As to line size, the 'correct' diameter depends on the cleat size (length). A rule of thumb is that the length of the dock cleat in inches times 1/16 inch. So an 8 inch cleat calls for a 1/2 inch line.
Choosing a too small diameter can cause the line to not snug up correctly. Too large a diameter mat not allow the line to slip through the cleat base.
The actual fender sizing is explained in the following video. These are general guidelines.
Reactions: sailUSVI
Picked it up today, had everything it needed, complete…cept beer.
Nice looking rig! I had a 215 with the same 250 on it. You’re going to love DES/DEC. I thought the cruise control was a bit gimmicky, but ended up very fond of it. Prop bite in reverse is enhanced so maneuvering is easier.
Cockpit layout and rear swivel seating makes the most of available space.
Oh, the livewell is insulated, so put your beer on ice there :)
Reactions: sailUSVI
First, congratulations on the new boat!
I go with white fenders because it's easy to see when they need to be cleaned.
Lines, I go with oversized 3 strand and I splice the loops myself. I prefer to have different length lines for bow/stern/spring - I don't need a 25' spring line (yes I know you can buy different lengths).
Reactions: sailUSVI
