LED REPLACEMENT BULBS
Break Time
Holland, MI.
Hi all,
I have an 06' Marlin & I would like to replace all the light bulbs in the cabin light fixtures with LED as the current bulbs get very hot. I have done some searching but there are so many to choose from I can't figure what I need or if there is actually a direct replacement bulb or if I would need to replace the whole fixture. If anyone has done this & knows the part# & where to buy them the information would be greatly appreciated.
When I did mine in my Sundancer, I got them from Super Bright LED's. They have pictures/descriptions of the bulbs so you can match up what you have with what you want.
Search here in the forums. Someone did exactly as you say for a 330 as I recall. I went and did as he did and am very happy. I looked in my maintenance notes and see that I replaced the 2 Vee berth overhead bulbs with a PN 30610-WW (warm white) at a cost of $16 each. Not sure but I think I bought mine from yachtlights.com. I replaced 4 other overhead bulbs in the main and aft cabin but do not have the PN off hand.
If you locate that post (from late 2013) - you'll be set.
Good luck and it's a nice little upgrade to do what you're thinking.
Good to hear!
One set of lights I would like to swap out to LED are - on a 330 Express:
- the 12" or so light under the microwave and
- the same 12" or so light in the head - under the cabinet
Each of these lights are under cabinet lights shining down onto the counter top.
Has anyone replaced these with LEDs? If so - please share your PN's and advice.
Thanks!
