- Jul 23, 2019
- Age
- 75
- Explorer
10/16/22 I have a 2014 I/O Stern Drive on my 1994 24’ Grady White. (350 Mercrusier Mag EFI , with less than 100 hours). On two occasions the engine has cut off while at idle and then would not start. Starter would turn over. Some 15 to 30 minutes later after being towed in, it cranked and ran fine.
Gas/fuel quality is not an issue. The fuel filter is new. The sleeve from the tank fill cap to the fuel tank is new. The boat itself has been restored to like new condition (new electrical as to boat, not sure as to motor) but to my knowledge the electrical, fuel pump if applicable and gas lines on the engine are original (2014 or 1994)? The computer is new.
Thinking it maybe some kind of sensor on the engine that when the engine is hot, the engine will shut down at idle then not start? I note that the engine has never shut down while up and running? The other known issue is that when I attempted to install a new raw water wash down pump, the voltage at the pump was less than 12. The pump would not run. The fresh water pumps do not work, they are original (1994) as far as I know?
