Minn Kota Riptide Terrova Quest 72" install on 2000 Adventure 208
rockfishon
Minn Kota Riptide Terrova Quest 72" Installation on 2000 Adventure 208: Project Overview
This document outlines my installation process for a Minn Kota Riptide Terrova Quest 72" trolling motor on a 2000 Adventure 208 boat. The motor has been acquired, and the installation is currently underway.
Motor and Mounting:
The chosen trolling motor requires a custom-fabricated aluminum base extension plate measuring 10" x 19" x 0.5". This plate is currently being produced by a qualified metalworking professional.
Power Source:
The motor will be powered by two 12-volt 100 Ah lithium batteries from Li Time. The chosen battery capacity is based on calculations to ensure sufficient power for intended usage.
Mounting Considerations:
Mounting the motor at the optimal angle on the bow presents a challenge, as it may partially obstruct the anchor well. While initial evaluations suggest anchor retrieval without motor deployment remains possible, further assessment during installation is necessary. The claim that electric motors eliminate the need for anchoring will be investigated throughout the project.
Additional Equipment:
The purchase of a bow mount trolling motor quick release bracket and plug is under consideration. The substantial weight and size of the motor raise concerns regarding the feasibility of solo removal, potentially rendering these components unnecessary. A final decision will be made after assessing practicality during installation.
Project Timeline:
The installation is expected to be completed within the next month. Updates, pictures, and insights will be provided throughout the process.
I received my aluminum base and currently trying to optimize the installation location.
Finally finished, except for the railing. Adding a couple of photos. The railing was under pressure so once I cut the railing it sprung wider. I need to find a good source for used railing so I can extend the cut pieces to make it easier to connect back together. I need about 12". I looked into powder coating the AL base plate but was unable to find a reasonable price for the service. I decided to prime and paint it and tried to color match the boat.
I decided to mount the motor with the power cable on the outside so hopefully it will not tangle with things in the foot area.
When I took it out for a trial I ran it for about 2.5 hours. It took 46Ah to charge the 2 batteries. It pulled the boat on the creek at 3.4 mph. I thought that another battery would help it out, so I added another 12v 100AH battery. Still waiting to try it out with 36V. I used 3x Litime 12.8V 100Ah Mini LiFePO4 batteries. I found a 60 A circuit breaker with a button so it will act as a disconnect and 6 AWG wire to run to the motor. The batteries are currently in the foot well of the cabin but I might move them to the rear of the boat starboard side.
