stonephoto said:
			Catch 22
I never really described my issue in the first place and thank you very much for responding.  I recently purchased the boat from a very meticulous owner.  I noticed while on the trailer that there was some seepage of water running down the transom from around the bottom area where the bracket is attached to the boat (around the bolt heads).  Not thinking much of it and assuming it was condensation I didn't question it.
Recently I removed the bracket's access cover and noticed that the caulking had deteriorated and had to be redone.  Looking down the hole I noticed the bracket had water in it.  I then went to drain the bracket by removing the plug with no avail.  The plug will not turn and I'm afraid I will break it.
The bracket is in very good shape except for some missing paint in spots.  I'm having it professionally maintained next month and figured I would ask the shop what I should do.
Well... again, based on what you describe, (and it sounds exactly like what I have seen) all you need is a decent re-seal. I had one grady, when I pulled the boat for the first time, the bracket was almost completely filled with water. Re-sealed it and never had a drop after that, (3 seasons in a slip). Like BobP said... put a heavy, wide bead on the perimiter. Smear it on with a wet, (water) finger. You can paint over it anyway.
Seal up the inspection plate - remove it and put a bead all the way around the mounting surface. Seal each screw. Imo, those plates do not provide a good seal, so I also seal the pop out plate itself. Should be no reason to open it after this. You check the bracket for leaks by simply removing the drain plug. And if for some reason you need to open the inspection plate, it will still pop out with some extra force.
The original drain plugs are aluminum. It's common for them to freeze up. if there's a little bit of the plug protruding out, give vise-grips a try on it. If not, drill a hole in the center of the plug and use an "easy out" extractor to back it out. If you do some searching, you can find a stainless replacement... or even plastic, (personally, I don't like the plastic ones, they seem cheap). I believe they are 1/4" npt. I've always replaced them with the standard bronze version, found at any boating store, or even Walmart. I dress the threads with teflon tape. The tape seals up the threads and also acts as a lubricant for easy removal.  Again... season after season, never had any problems.
