Motor well scuppers
kevgle
Trying to send pics the scupper on back of transom for the motorwell.On the inside The brass piece has corroded off .Its above the waterline.I presume this is all one piece thru the outside.i was thinking of using sealant to put that brass piece back on for the season.Any ideas .thanks boat is 265 exprrsz
If the inside rim has broken off from corrosion, it's reasonable that the other side will in short time.
Don't do a band-aid repair when the real repair is easy and doesn't take long, at all. Chisel the old tube out, pop a new tube in. Check out TH Marine's website - they have nice plastic, 2-piece units that zip together.
