- Jun 11, 2020
- Age
- 46
- Long Island
- Tournament 225
UPDATE:
tonight I layed in one layer of 1.5 oz csm. I coated the core, marine ply with resin and let it sit for about 45 minutes. Then I made some peanutbutter and troweled it onto the core than layed it in place. I probably couldve used like another 3 oz of resin to wet out the csm. Tomorrow ill finish it up witha layer of 1.5 csm and a layer of 1708.
I began recoring my auxillary hold panel. 1st off for those that say polyester resin doesnt stick to plywood, I'd say you never did this before,lol.
For today I removed old wood amd quickly ground out the skin. I need to get the corners better and if I need to all the little pock marks?
Ill up date the post as I go. Im going to use polyester resin and regular plywood to be cost prohibitive. Ill pay attention to ensure everything is sealed properly. Im going to reinforce around the inspection panel and repair the gel coat side. There are a few crack i need to mend as well.
I had intentions of re gel coating the entire thing but I may just go with an epoxy paint a d try to color match the rest of the deck.
