2001 Marlin and the freshwater pump will come on when I flick the switch over to pressurize the system and then every few minutes it will come back on again. This probably means a leak somewhere. The pump itself is mounted behind a wall in the mid berth and opposite to that wall is a Y-Valve that I can check for leaks. We found loose hoses clamps in both areas a few years ago and that will be my first stop.
I have 4 water outlets and I've pretty much ensured that none of them are leaking too. Any other ideas or suggestions on where to look or trouble-shoot? Yes, the tank is full......
Thanks!
Thanks!
