- Mar 13, 2013
- Atlanta / Carrabelle, FL
- Express 330
I have a 2002 330 and have been battling an issue with the lift out hatch for the generator and strainers for the four years I've owned the boat.
The only way I have been able to keep water from entering the aft bilge is to caulk around the hatch but it is a royal PITA when I have to get access to the area. A couple of months ago I stripped all of the caulk away and tried to seal the gap with 2 different thicknesses of braided rope. It's better than nothing but still not real good. Last week I was working on the boat and got to wondering if the seal had been compromised by the prior owner. The bolts that go through the hatch into the grommets just push in, there are no nuts in or under the grommets. Is that true for all of your boats or are the grommets supposed to have nuts imbedded to draw the hatch tight against the gasket?
If the grommets are truly just push through design, have any of you found a way to secure nuts to the grommets?
If I have to get creative to solve the problem, I will let you all know when I find a solution.
Regards,
Regards,
