Its been a mixed season on my Explorer and now time for a big winter project.
Started with a seized lower unit- Second hand fix but did nt help for long.
But the real fun was a seized engine this weekend. I cant move it an inch. I was a way from home and had to limp in feeling very vulnerable as the Bridgeport ferry pulled out. I have no confidence in the boat anymore and with the kids often with me alone I'm taking no chance from here on my 15 year old set up and I need some advice from anyone that put on a new bracket and a big single.(pair of 94 150s for sale one seized +controls)
My scuppers are underwater with the 2 150s so I want to add some buoyancy. Hermco is so very expensive so i wanted to go with an alluminium Seaboard, Stainless marine or D and D? Any negative experiences? Do the V shaped brackets help reversing?
I'm going to go for a 250 or 300 Yamaha or Verado 4 stroke as they are my local guys. Is a single weighing 650/700lbs replacing 850lbs of twins an issue? I only go up and down the LI sound so I dont think the cost of twins can be justified and I wont miss oil tanks.
The bracket tends to swamp when you come off the plane so would a 30 inch motor help if i raise the bracket a couple of inches? (or will i get drag too much)
I'm going to replace the fuel tanks and every thru hull and hose on the boat, but is it ok to change the main tank for alluminium then put in a smaller plastic auxillary or do the tanks form part of the hull strength?
THANKS in advance, this site really is brilliant for researching a project.
