Doc Stressor
- Nov 13, 2009
- Homosassa, FL
- Seafarer
An even easier solution than a terminal block is to use gel filled telephone splice connectors. They are dirt cheap and completely waterproof.
http://emoics.info/bright-navy-blue/telephone-splice-connectors.html
You want the red ones for the little NMEA 083 wires. They come in 2-wire and 3-wire types. The 3-wire ones let you connect 2 NMEA devices to your GPS antenna simultaneously. You just crimp them on with a pliers and fasten the splice wires with tape or a wire tie. I've never had this type of connection fail.
