I was out cruising the Coral Sea today, heading for some new grounds about 2 hrs out at 28 knots.
We had been running for just over an hour when the low oil alarm came on and the revs died (as they should) Luckily weather was perfect so no need to panic just get the manual out and did some research.
As the engine was not overheating next suggestion was try the oil filter. The reservoir on the motor was on the low mark; but the oil tank was half full.
Checked the filter on the motor it appeared fine. Found the little filter at the base of the oil tank pulled it and it looked ok also ........blew thru it both ways.....no probs. Topped up the reservoir on the motor and while the rear hatch (265 express) was off ,pulled the electrical connections on what I think is a small pump on the side of the oil tank ? sprayed the connections and reassembled.
We then trolled for an hour ....towards home ......and then cruised home for an hour with no sign of problems. When we got home I checked the oil reservoir and it was at the full mark(as it should be )
Anybody had this happen or any suggestions before I take it into the shop? Thanks in anticipation......needless to say we didn't get to fish the new grounds!
