Just a tip when replacing the fill hose, keep the hose as short as possible and do not allow any "dip" in the hose. Run it as direct to the tank as you can. Reason being, when your on the back of the boat in the water, bow is pointing up inhibiting flow to the tank. Any dip in the hose will only make this worse. My original hose ran into the bilge, then up to the tank. Made for a long slow fueling process, even with extra people on the bow.
