I have put down a deposit on a 1986 GW 204 Fisherman.
The motor is a 2000 HPDI 200. It only has 140 hours on it. A Yammie tech put the computer on it. No fault codes, no warranty issues.
The hull is another story. There is delimitation of plywood on starboard side of anchor locker. The surveyor got high moisture readings in the deck, the bottom of gunnel walls and the bottom of the hull. Tapping the hull, he found some dead spots. I know boats that are 30 years old are going to have some moisture. But the hull and transom are pretty solid, save the moisture readings. He also thinks there was some repaired blistering on a small portion of the bottom of the hull.
He wants $10,500 for the boat. Boat has been in a warm climate. Rewired. And that was done well. New fuel gage. Small Lowrance FF. Old vhf radio. New stereo. T top. No compass. No chart plotter. Plenty of rod holders. Trailer in decent shape.
What do you think.
I'm worried about the moisture readings. And the wetness of the boat, in the surveyors words.
Thanks in advance for your input.
What do you think.
