- Nov 18, 2019
- northern New Jersey
- Offshore
So I got the boat in and when running at wot it began to over heat. Beyond the temp coming up it felt like i was dragging an anchor. So cruising at 3600 rpm or so it seems fine except terribly slow at about 15 mph. When I was back in my slip at idle the warning sound went off again. Both times I was getting water flow. Could I have a bad thermostat?
back to performance, it definitely does not run as it should at wot. I would think I should at least get 23 or 24 knots. That being said I put 2 Garmin transducers and a panoptic transducer pretty much on the center line as much as possible. Now I have read that may not be a good idea because it could be causing bad water in front of prop. i have a 225 optimax with a 17 inch pitch not sure of diameter, I will mostly be running full fuel tanks and 4 guys plus cooler, gear and 2 anchors. any thoughts/
