I have 1994 175hp black max I have changed the water pump changed the stats twice rebuild the popet valve , removed the lower end to make sure there was a seal between the water pump and the out going gas chamber , flushed with vinegar finaly pulled a head to see if the water jacket was blocked it is clean . What is left ,it runs great at 1000 rpm above 3000 rpm the temp goes up untill the alarm goes off . its a twin and I have switched the temp sensor . I would love to repower but need to keep it running for another season or two . help
